DO NOT CLEAN IT!!!!! It is not a MAF type sensor it's a KVAFM (Karman Vortex Air Flow Meter); They're OPTICAL!!! You can completely ruin it. If you've tested it per the TSRM and that all pans out then check if someone in your area might have one you could swap in to test with.
Have you checked for diagnostic error codes and fuel issues?
