hey sup guys im looking to rebuild my motor in my 1988 7mgte twin cam, the kit that i found is like $425 for the non turbo and mine is non turbo but im not sure if it would be any diffrent if i would get the turbo one it comes with
This kit contains complete gasket set, set of pistons and rings, main bearings, rod bearings, thrust washers, timing belt, balance shaft bearings (if applicable), and a set of expansion plugs (does not contain camshaft, timing kit or oil pump). Pistons & Rings: Std., .020, .040. Bearings: Std., 10, 20, 30
im not sure if it would be any better or if i would even be able to do it . because if i go with the turbo one its cheeper . the web site is
http://www.rpmmachine.com/shop/index...t_detail&p=215 thanks guys !
