It is always best to go back with original and same year stuff. So like she said, if you can find a complete 7mgte for your year you will have a better start, but there will be extra things you will need to make it all work. Guages, hoses for oil feeds and water lines, maybe different cable systems................etc. If you had the donor car right there it would help quite a bit.
Not trying to discourage you, but unfortunately it isn't just a plug and play.
Russ
