Thats not what statistics say. But anyway you will still be slow with 200hp hauling 3500lbs. You still will be in the range of 0 to 60 in 8 seconds. Even a newer v6 mustang will beat you.
And wow that is alot of miles. I'm glad to see another 7m run so long. I would ceratinly say a rebuild is order as well as alot of other things. If you stick with the ge and it is rebuildable. I would work on suspension next which probably needs some care to.
