well... off course the 6m is little better then the 5m. n the 6m in japan it does came with the turbo. n its rare to find in the US with the 6m. but anyway if i were you i will put up the 7mgte cause the engine mount were bolt right up tho. n bout the 6m. well it do it but less hp... then the 7mgte. hope you got ur car to work someday. post up the pix when you done working on your motor. peace.
