Old 01-12-2011, 02:44 PM   #10
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by 2JZDU View Post
I tool it to mechanic, cause I couldn't find any diagnosis tool around....
"Diagnosis tool"??? What on earth are you talking about? Where did you get the idea that you had to obtain a "diagnosis tool"?
All you need is a paper clip to "Connect terminal between TE1 and E1 of data link connector 1 or 2". Didn't you read the link I posted???
http://www.mkiv.com/techarticles/eng...bd1_codes.html
That tech article does NOT mention a "diagnosis tool", in any way, shape or form.
If you don't mind me saying so, if you'd have fixed this yourself instead of taking it to a mechanic, you would have learned "relation between cam sensor and cold weather".
Life begins at 30psi.
