Old 01-12-2011, 02:52 PM   #11
2JZDU
2JZDU is on a distinguished road
"Diagnosis tool"??? What on earth are you talking about?
All you need is a paper clip to "Connect terminal between TE1 and E1 of data link connector 1 or 2". Didn't you read the link I posted???
http://www.mkiv.com/techarticles/eng...bd1_codes.html
That tech article does NOT mention a "diagnosis tool", in any way, shape or form.
If you don't mind me saying so, if you'd have fixed this yourself instead of taking it to a mechanic, you would have learned "relation between cam sensor and cold weather".
yes I read that, but I just don't understand where can I found the codes after I connect those connector, cause I throught I will need a computer thing to plug in the connector, then code will be shown on the screen.
2JZDU is offline   Reply With Quote
