I suspect s blockage may be to blame... blockages and bad thermostats are common culprits for problems like this. Old hoses may collapse too as there is a natural vacuum in the system. I'd start with testing/replacing the thermostat.
BTW, your first posts were both in moderated sections intended for different purposes. Please check where you're posting before you do so. This is the correct section.
