Old 01-19-2011, 11:58 AM   #7
Busted Knuckles
Busted Knuckles's Avatar
I meant to add that you should only need to drill out the center tumbler section of the lock cylinder. Just to be able to remove the tumbler pins to get the cylinder to turn. Then use a screwdriver and rotate it to the ACC position, depress the pin, and out it comes.
