i know it sounds sketchy but search ebay ... 2jzgte with 6 speed and harness ecu fuel pump etc it just under 3500 shipped to your door with less than 50k on it just my .02 this woud be the most straight forward swap and probably the cheapest or you could always just turbo your car as is the 2j is a good engine and the n/a block is almost if not just as good as the turbo
http://cgi.ebay.com/ebaymotors/JDM-T...Q5fAccessories
ive bought from them before and was happy with it you can get one with a 6 speed for anothe 2k
92 miata 7mgte swap  forged pistons,studded mhg, 3 inch dp with a glass pack,blowthrough MAF-T,550cc inj, act stage 2 clutch, fmic kit, greddy rs, full wire tuck, rx7 lsd rear with 4.10s. 15psi "ct26-A"??(waiting on dyno #s) if anyone knows whats up with my turbo let me know it has a larger comp wheel nicer machining and 6 dual fins rather than 5? its confusing and keep finding too much contradicting info. would LLLLLOOOOOOOOVVVVVVVEEEEE a compressor map
