don't know, I'm not sure how to test coil packs, any advice?
been reading around for the past hour, only seen testing for the 7mge distributor setup, but not for a 7mgte coil pack.
can you do the same thing with jumper cables or just run the spark plug out of the plug wire and see if it sparks?
i've got extra spark plugs but dun wanna do it if my problem is fuel related, it's gotta be one of the two.
a friend of mine told me to get some "starting fluid" and spray some in the throttle intake system and if it starts with it then eventually dies the fuel pump/filter is faulty...?
just the thought of the stuff makes me laugh but i've seen some videos of it actually working.....or starting a fire... so uhhhh
