or should i do this dp..
http://cgi.ebay.com/ebaymotors/Toyot...Q5fAccessories
I keep hearing that divorced dp is the way to go.. idk though.. Is it legal in Oregon. Is it legal at all. You can't use test pipes here.. Anyways I don't think it is since your bypassing the cat in some way. Anyways, what one is better.. Most likely it is better because if you can create anything that is somewhat a bypass you get a gain (in a turbo car)..
