start signal ? put a booster relay on the starter to solve the problem i had with the starting. havn't needed to check the fault codes since then, that could be it.
put cam timing back to norm, ended up with spark timing at TDC and idle at about 12 hundred. moved timing back a bit and it sped up. ill check for leaks ... its blown back a few times in this whole stage of trying to get it going -ness that has taken so long ( heh scared the crap outta our battery stock man last week when it blew a blue flame at him thru the disconnected 3000 pipe
i was hoping for a big *bwhuum* ). that coulda knocked something lose.
