If you don't machine the head when it is needed then you are just asking for trouble. As well as cleaning the head and block surfaces is a must. The spray is just a good precaution to take which helps seal and improve heat transfer. It is most certainly not a cheap way to avoid the machine shop.
http://www.permatex.com/products/aut...ve_Sealant.htm
