more info needed
how does the alarm disable the car? while driving? its possable the door key lever isnt contacting the alarm switch inside the door so when you unlock the car door the alarm goes off and car wont start after that? or what do you mean? the power steering leak is most likely just the feed or return line. mine leaked, just tightened up the clamp. and the altinator is sweet. brushes are mounted under the back coverplate and are easily removed for inspection. if the armature is still in good shape? slap in some new brushed and you should be good to go. worked on mine..
