It's a bitch to do I can tell you that....There is like almost no room to work with....Measurements of the down pipe are almost always off....Make sure you have new bolts and lock washers ready.....Some PB blaster a friend to help you re attach the cat to the down pipe because it's a bitch....Probably want to go ahead and get new rubber anchors for the exhaust too because they are probably dry rotted and cracked but anyway good luck with it.
IF IT AINT A SUPRA IT AINT SH*T!!
87 Supra N/A JDM 7MGTE, 8psi, 2.5inch Exhaust, 18inch Rim's, 255/45/18 rear, 255/40/18 front, 3inch DP, Ported 3inch elbow, Stage 2 6 puck Clutch
95 Eclipse GST 15psi, 3inch Stainless Steel Exhaust, 3inch DP, MBC, 2.5inch Upper I/C piping, Short Throw Shifter, Stainless Steel turbo inlet, Type S BOV (Sold)
89 Supra Turbo, 12psi, 3inch Exhaust, Ebay intake, 2.5inch Upper I/C piping, ARP Head Studs, Stainless Turbo Manifold Tial BOV (Sold)
(Sold)
