The 2JZ-GE takes a turbo much more readily than the 7M-GE.... MUCH MORE. You can even run it on 7M electronics but you lose some power potential there. At a minimum I would run the 2JZ-GE electronics along with an aftermarket boost controller and upgraded injectors... Best would be running 2JZ-GTE electronics with stock 2JZ-GTE injectors or better and a good fuel controller.
It's been a long time but I think there is even a suitable oil return from the turbo.
You should check in the MKIV section for additional info though.
