One important difference is that the aftermarket HGs are available in different sizes. The stock Toyota HG is 1.27mm compressed. Also, while the stock HG is much more forgiving of flaws in the deck of the block and head, you should get the head milled regardless and if there's any significant pitting on the block deck or any warpage beyond spec you'll need to get that milled too.
