First thing id check is make sure the ignitor is plugged in or even present..its next to junction box, specific for the 1jz.. THEN recheck that you have compression and fuel... Check plugs while your in there. Also inspect the coils for cracks and be easy on them they break fairly easy.. I'D check the timing belt if everything else checks out.. make sure dead timing is set properly (all the marks line up).
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
Reason: Need more sleep!
