Originally Posted by wcrispino
Thanks for the response pwanas, just wondering is there a special tool that can be used to get the pulley off. Tried to put a bar to try and crack nut off but is very very tight!!!
Any other advice would be appreciated.
Cheers
If you agree to post back here at every step of the way, I guarantee you we'll get it off.
One step at a time - right now, your problem is that you can't apply enough power to the bolt with the tools you have. The solution to that specific problem is that you simply need more leverage. You need to find/buy/beg/borrow/steal a long, strong pipe that fits the end of your pry bar. Put the pipe on, and push. With a long enough pipe, you could flip your car over, or tear the engine off the motor mounts. However, something else will happen first. For example, your clutch may slip (if you have a 5spd). Post back and tell us what happens next.
