Originally Posted by toysuprapr
Every morning i start up my car and blue smoke shoots out of the exaust then stops. Some people told me thats it could be the turbo seals others told me it could be the valve seals. Any engine tests i could get done on my engine to confirm the problem?
Unfortunately there is no test other then to take your exhaust off and see if there is oil in the turbo... the exhaust side is where both of my ct26 seals blew out. but it could possibly be the compressor side... you are talkin about a 7m right?
Could also be valve seals. I just got done replacing mine on my jz. They were rock hard and one had fallen apart. You can see if the exhaust side is leaking by pulling off the manifold and lookin at the valves. If they are bad they will have oil seeping. Valve seals can be replaced with the head on!
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
