Sorry I should of read what section this was in. The ct12b on the 2j are good quality turbos. The valve seals that were used for some reason have a high failure rate... I used felpro seals as a replacement cuz they are made of a Viton rubber which is very durable..
Here is a good how to....
http://www.mkivsupra.net/vbb/showthr...al-Replacement
Ps. Get the valve spring tool it is worth the money.. I used long long nose needle noses to pull old seals out and it worked good! But get the valve keeper tool!
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
