Alternator
If your MKIII has a bad alternator the brake light, battery light and rear warning light will all come on so all your litghs coming on is normal. That is it is normal if your alternator is bad. Also make sure you have the right alternator, Toyota change that alternators in mid 1987. And the turbo modle uses a different alternator than the non turbo as does the manual and auto trans.
