Do not re use your head bolts. Go with arp studs or bolts
To use a metal gasket you have to have a really smooth finish that can only be acheived by machine shops on both head and the block..
Or to save your self from tearing your engine apart. Swap a 1jz in. It will be the best decision you ever make! Although 7m are wicked engines. They just are not near as reliable as a jz. And you don't have to open it up to make it reliable! Just my opinion everyone has there own on this subject!
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
