Originally Posted by Sonyps307
Just loosen The screws on the tps then do the jumper. when it flashes code 51 turn the tps intill the code goes away. Now recheck for codes.
Not the best way to do this. The specified gap is there for a reason. It's alright to do this for testing purposes but you may have intermittent idle issues.
A code 51 will occur if the A/C is turned on while the diagnostic is running or if you press the throttle too.
Additionally, a bad TPS isn't going to cause the problem you're describing.
