I'm having trouble with the passenger side window. The whole time I've had the car, the pass. window would roll down but not up, (I have a 87' turbo by the way), and when I hooked the battery directly to the window motor it went up and down. If the switch goes out on the pass. side will that affect the driver side switch? Because it will usually go down when pressed from either switch but not up.
