that cold power issue def seems like tranny problem, i recently just started having a similar problem with mine, but it rarely gets that cold here. Sometimes when that happens to me, i'll shut off the car and then restart the car and it seems to work and have it's power back. As for your other issue of not starting, I'm not to clever with cars but it sounds like a timing thing... also to check if your getting fuel, just pull a hose off after the fuel pump and put the end into a jar and crank the engine. If there is gas in jar when you check then pump is working. Hopefully someone with a lil more knowledge will chime in and give you more advice.
