Originally Posted by Piggy808
...its always bogged and the timing setting was at about 12 degrees Advanced from TDC...thats when i got the car...I advanced it to about 16 degrees cuz im a noob at this kind of stuff and i guess i got the gear on wrong for the distributor and could only retard it to about 15 degrees...
A few days ago i decided that i should try and put the distributor on right and the timing back to 10 degrees like the manual says. and its back to bogging at the lower rpms at the factory settings.
So check mechanical timing too? so the distributor timing advance does nothing that the ecu cant adjust...so, why do you think it ran better when I had it at 16 degrees advanced?
Everything you're saying here makes me think the timing is off... either the mechanical timing is off or you're not properly setting the ignition timing. It's also possible that you are squeezing a little more power out of it but not safely... Don't run at any significant advance without higher octane fuel, it's begging for a rebuild. Yes, the ECU tries to pull ignition advance if knock is present, but it can only ever pull or add so much, you're shortening the systems safety net.
Also about the octane booster...87 plus..lets say a good octane booster...that will be sufficient for fuel? I gotta take advantage of my free 87 gas situation  .
If you want to stick with your free fuel you gotta be willing to toss in $10 of toluene with each tank. Remember, the octane booster ALWAYS goes in the tank BEFORE the fuel; That way it gets properly mixed in.
As for cleaning out the pistons and stuff...I did what nickleeye suggested in a post...used some carb cleaner into a vacuum and just ran it a bit.
I prefer MCC, a bit nastier. For a thorough clean you may pull the spark plugs and spray in a good amount and let it sit overnight; Just spray in enough to fill the piston domes. Most of it should be evaporated by the next afternoon and it will be hard to start after you put the plugs back in.
