The passenger switch's circuit runs through the driver's side switch. It's not uncommon for carbon to buildup on the metal rocker contacts in the switch causing a disruption in the flow of current. You may disassemble the switch and lightly sand the contacts and see if that's the sum of the problem... this happens in the passenger side switch too, but if you can't operate it from the driver's side start with that switch.
