Old 02-23-2011, 08:43 PM   #11
Originally Posted by rjSupra View Post
Any thoughts what that wisp of smoke behind the motor, close to the firewall could have been? And the slight plastic-y burning smell? That happened the last time I tried to start her, with a paper clip jumping either the engine error code check terminals, or the fuel pump 12v bypass I can't quite remember which one I had it in.
Sure.... the wire harness. Start there. Check to see if you can hear fuel moving through the fuel rail with B+ and FP jumped... check if B+ has a constant 12v.
It sounds like the 02 sensor can't be at fault for all these issues, so I appreciate knowing that now. Don't really know what they do aside from I gather measuring oxygen levels in exhaust to send setting info to the car for fuel rich / lean levels etc.
A bad O2 sensor may be good enough to cause a slightly bad reading.... Usually when they go though they're so far out of range that the ECU disregards the sensor altogether.
