Old 02-23-2011, 09:06 PM   #12
rjSupra
rjSupra's Avatar
rjSupra is on a distinguished road
Sure.... the wire harness. Start there. Check to see if you can hear fuel moving through the fuel rail with B+ and FP jumped... check if B+ has a constant 12v.
Yeah, thanks, already jumped this and verified that I can hear fuel moving through the fuel rail. That part is good.
A bad O2 sensor may be good enough to cause a slightly bad reading.... Usually when they go though they're so far out of range that the ECU disregards the sensor altogether.
My current weak hope is that the super cold made it too hard to start, which I know doesn't really mean anything or make sense. I am pretty sure I've started her that cold before. I'm going to have to look into this ignitor thing too.
88 Supra 7M-GTE Turbo, TEMS, Targa stock
rjSupra is offline   Reply With Quote
