Old 02-23-2011, 11:15 PM   #7
jtown125
jtown125 is on a distinguished road
I hooked up 2 different head units with sub outputs with neither of them working. Both had setting for amp install and sub settings. (I didn't have to manually set up anything for the amp or sub to work with the head unit) The only thing I can really think of is something in the stock harness that is making it mess with the rca's or something to that extent. The only other thing I can mention is that the right front speaker goes in and out on occasion. (not sure if that has anything to do with it or not)
And the signal wire (remote wire??) yes...I hooked it up to the stock power antenna wire...(sub will only hit when radio is on, NOT CD, AUX, and etc...)
89 mkIII turbo supra stick black w/ maroon interior!!!
jtown125 is offline   Reply With Quote
