Old 02-23-2011, 11:45 PM   #10
Originally Posted by jtown125 View Post
(sub will only hit when radio is on, NOT CD, AUX, and etc...)
Wait.... what? Are you saying the subs do work part of the time? If the remote/signal line is a gnd input try grounding it to the chassis and see if it functions continuously; And, if it's a positive signal then try connecting it to a full time positive signal.
Post the make and models of what you're running (dammit)...
EDIT: Oh, and the speaker going in and out is more likely bad wiring. If you're using the stock wires for the regular speakers there may be a break in the section which crosses from door to chassis.
You're not using any of the stock wiring for the amp and subs, are you?
