None of the stock wiring touches the amp or sub wiring. The cd player had a harness kit put into it to plug up to stock harness (remote wire is ran into the kit between the cd player and stock harnesses)
And the sub doesn't hit at all, I have it set up to where it will only hit when the radio is turned on (when the antenna gets power, the antenna doesn't come up with the cd setting or any aux setting)
(make and model in sig)
89 mkIII turbo supra stick black w/ maroon interior!!!
