Here is the how to for the auto and to do the 5speed swap you need.
•master
•slave
•lines between the master and slave
•clutch pedal
•shifter
•Transmission
•front part of drive shaft
•flywheel
•clutch and pressure plate
And a few other parts that I can't think of.
Also if you do a R154 swap get all the part that match That transmission and the same if u do the w58.
