Thread: Internals
Old 02-26-2011, 07:59 PM   #2
Travis89Turbo
Travis89Turbo's Avatar
Originally Posted by itsjustsway View Post
Where can I find the rods and pistons as a set? And I can imagine fuel cut off will be a big problem after those mods. For injectors I go to the junk yard and search threw cars, I picked up 550cc injectors but still the rest of the crucial parts. 680cc would be alot better so where do I begin to look? and for the rest of those fuel parts
You will be so far past fuel cut at those power levels your forget what it is.. if you use the EMS stinger you can adjust fuel cut to whatever you want. If you use oem ecu with a piggy back you will need hks fcd but that is not really fully adjustable pretty much has just a few settings and none of them are written in stone. But they do work great to get the job done!
I hope you know you will need a bigger turbo to make those power levels.
I really dont reccomend running junkyard injectors! Without atleast sending them out to get rebuilt and mapped! which cost almost as much as new injectors See links.
here is some links to some parts....
JE
http://cgi.ebay.com/ebaymotors/JE-Pi...Q5fAccessories
CP
http://cgi.ebay.com/ebaymotors/CP-Pi...Q5fAccessories
Cams
http://cgi.ebay.com/ebaymotors/BRIAN...item3a614a2a7f
Springs & retainers
http://cgi.ebay.com/ebaymotors/Brian...item43a056d6e1
Turbo
http://store.driftmotion.com/static/...-1turbokit.php
Ems
http://store.driftmotion.com/static/...ndaloneecu.php
Injectors
http://store.driftmotion.com/static/...ors6wclips.php
AFPR
http://store.driftmotion.com/static/i-afprkit7m-gte.php
As you can see it gets exspensive real quick.. But you gotta pay to play!
Hope this helps!
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
