If you have the money might as well get the parts that you already found and have for them. getting the wiring harness and transmission are hard to find. The other stuff are easy though.
Also if you have a buddy or two to help it will make things a lot easier. The 4 top bolts are a pain in the @$$ since you have to unbolt the tranny and let it tilt all the way down and use 5-6 extensions to be able to turn them a lot.
