Thread: 2JZ-GTE Swap
Old 02-27-2011, 03:33 AM   #1
907mge
907mge's Avatar
Default 2JZ-GTE Swap
Well here it is the JDM 2jz my friend Trevor picked up from NJ this morning. It was $1700 for the motor,ecu, and auto tranny. The motor has a tag in japanese that says 92k Km, which I guess is the milage for it. Although this is the first step atleast the motor is here. It will probably be a good bit of time before it goes in. For now it will be going up on the stand to have the oil pan switched out.
And here is the mk3 that it will be going into.
The swap will probably end up taking a while since it will be a part time project, but I will try to document it as it progresses though.
