Then you start your soldering... i didnt take any pics of the anti wicking tweezers.
Then the first bundle completed. This is not it wrapped up completly if you twist it up how the factory does it is hardly noticable thatits been soldered
Three bundles complete with just the 4rth one left and all the signal wires from knock sensor/cam position/ crankshaft etc.
This is how i labeled the bundled wires like the crank sensor/cam etc etc
I then went back to the engine with the ecu plug end of the harness i just extended. to start soldering it back into 1 piece.. By this time you should be one hell of a soldering master! IIRC there is around 300 wires you solder!!
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
