Old 02-27-2011, 09:47 PM   #1
Travis89Turbo
Travis89Turbo's Avatar
Here is some pics of the harness soldered together!! It was a great feeling!
Name:	IMAG0209 (640x383) (640x383).jpg
Name:	IMAG0210 (640x383) (640x383).jpg
As you may kno the jza70 and ma70 use different plugs! I didnt want to cut my chassis plugs so i made these plug adapters for all plugs needing changed. This adapter goes from IH2 to C1 Ill attach a link with all diagrams they are even colored! it shows plug to plug.
http://1jz.com/tech/docs/wiring/
The wires hanging out the side are for A/C and the three tied together are for the Alternator which need to be soldered to chassis.
Name:	IMAG0212 (640x383) (640x383).jpg
Here is the chassis cleaned up for the most part gettin ready for its new jz! I still spent abou 3 hrs after this pic was takin cleaning everything up! I like bein able to change my oil without gettin Lubed myself.
Name:	IMAG0215 (640x383) (640x383).jpg
If you plan on runnin your AC Which i did cuz it gets hot down here! And nothing better then kicking someones ass while you AC is blowin on you in 105 weather. Your gonna have to pull this stud out that holds your ac compressor and replace it with a bolt cuz it hit the Top plate you have to take off the 7mgte ac compressor. You also have to notch out the powersteering bracket due to the bolt that holds the ac hoses on hit it! DO THIS BEFORE ENGINE IS IN CAR!
The stud that needs removed.
Name:	IMAG0216 (640x383) (640x383).jpg
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
