Is the rushing water sound kinda like a waterfall? If so, that's a sign of air in the cooling system. Usually a good long "burping" session can clear this up. Be sure when burping to get the nose of the car as high as possible.
And fix the leak, regardless of if it causes the problem you're noticing.
