Newer Civics have no problem keeping up with the 7M-GE.... I mean 3500 lbs and only 140 to 160 HP at the wheels? C'mon....
Lucas is garbage, if you're going to run an in-tank fuel and chamber cleaner get something good: Techron, 44K, Redline SI-1.
And if I hear of anyone here ever using Lucas oil additives I'm going to BAN THEM!
Check your intake plumbing for leaks or cracks, replace the vacuum tubing, test the AFM. You can try running with the TPS unplugged and see if it drives better; If it does, replace it.
