Ok guys/girls ...I need you to school me in supra/lexus drivetrains. I'm in the process of a major project that will be using a supra/lexus drivetrain. I need to know what set up I should choose. This is going to be a drag car...so i'm not really considering convenience. Is the 5 spd or 6spd transmission better. Which tranny has the better gear ratio for drag. Is there a large difference in strength between the turbod and nonturbod trannys? I also need to know the year of the cars I can get the transmission you suggest out of.
I need the same schooling regarding the rearend. Which one is best/strongest. Does it come with an lsd? Once I get this rear end what lsd or spool do you recommend? Keep in mind I dont care what yeart supra or lexas..it could be a 2nd gen or 3rd gen. I need more than one option from best to worst for the transmission and rear end.
Last but not least...what problems to look out for with the drivetrain given.
You guys will be a big help if you could answer these questions.
Please no flamers.....and questions are welcomed.
