Old 03-06-2011, 01:48 AM   #20
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by 2JZDU View Post
hi mate, I need your help again. Today I found my check engine will on if I drive over 140Km/h, but if I shut it down and restart the engine, the light will go away, I think might be a false o2 sensor. Anyway I try to diagnostic what the problem really was, but the weird thing happen.
engine light flash once, after one second, it keeps flash 4 times quickly, after one second, it flash two times more quickly as well, then go back to beginning.
I looked up the table and I couldn't find any condition of 2,
do you have any ideas what that was? I am very appreciated.
One of the two codes appears to be 14, right?. Let's start with that:
14
Ignition Signal
No IGF signal to ECM for 4~7 consecutive IGT signals with engine speed less than 3,000 rpm.
  • Open or short in IGF circuit from igniter to ECM
  • Igniter
  • ECM
ONn/a
Yes
It seems you may have a problem with your igniter. Did you ever get a TSRM for your Supra?
Also, please re-check those codes. I don't think it's possible for the ecm to give a single-digit code. Perhaps it's 22?
Life begins at 30psi.
