Huh? From the slave to the fork? The slave it directly in contact with the fork... there's no hose there. It's a simple hydraulic, the only hose runs from the master cylinder (whose piston is connected to the clutch pedal arm) to the slave cylinder which is bolted to the bell housing (whose piston pushes the fork). The line runs from the master as a hard line which then connects to a soft line for the run from the firewall to the slave cylinder... So it's half and half. :P
I thought you had already ordered the hose?
