#1 you have to swap your wireharness off of your old 7mgte and put it on the jdm 7mgte it all hucks up the same #2 you have to sawp the in take because of the right side throttle you will need to get a platium gas it for it you can get it at any part place and the throttle brackit off of the old engine #3 the oil send unit has to be replace too and why you are doing this sawp replace the timeblet to and put a new all cluch parts in it why u have it out and the engine mounts the pic im puting on here you have to go to my myspace too see it u dont have to have a myspace to look at it start from pag 8
http://www.myspace.com/graywolf1969/...over_ViewAlbum
