Originally Posted by cre
If the cracks are in the head, you could have it welded but it's probably going to be cheaper to just source another.
If the cracks are in the block, it's trash. You can't weld cast iron blocks with any reasonable reliability.... Not saying it can't be done but it usually fails gloriously in no time at all.
So I would b better of buying another block or a whole new engine? The welds won't hold because there's 2 much pressure right
