I've answered this a few times in a few recent posts.. It depends on what specifically you're talking about. If you're asking if you can use the engine minus the turbos then I've answered it in the first reply. If you're asking if you can run a full GTE setup, turbo and all, on GE electronics then the answer gets quite complicated... to put it simply or safely: If you have to ask, then *no*.
The short of it is that you can run just about any I6 engine with the electronics from almost any other I6 engine... but you need to ensure that any variables that system may not be aware of are addressed (such as using the electronics from a system not built for a turbo on an engine which has one).
