Old 03-08-2011, 05:06 AM   #2
Blow off valves release pressure... they don't cause it. I advise you start with a new mechanic before you get new parts.
EDIT: Okay... that was a bit short and pissy. Let's get caught up... If the BOV is the source of the problem, has he already replaced it? By the way, the stock OEM BOV defaults to open when it fails... hence you get less pressure, not a BIG increase.
There aren't many direct fit kits for the MKIII, most of what you find on eBay are "universal" kits which require a good deal of planning and some work to get them to fit... they're not terrible, but it will be some work. The universal front mount intercoolers will require the fabrication of mounting brackets too.
If you search around you can find Spearco replica ICs which have the same mount points and the piping is in the same location as the stock setup; it's a lot easier. 2.5" is a nice size increase and it's about the biggest you can fit without difficulty. If you do get a universal kit off of eBay then you'll want to make sure the couplers which come with it are either 3 or 4 ply silicone of good quality and do not use standard hose clamps.
Now, if your mechanic's telling you what needs done, why didn't he cover this? Sorry... I hate people who half-ass the job.
