Lots of penetrating fluid like Liquid Wrench or PB Blaster. Soak it all night, maybe all day too. If that doesn't work I've heard that you sometimes will have luck if you heat the nuts up first with a torch, although I've never had to resort to this.
When I dropped an A340e, I believe I did drop most of the exhaust (actually, I think it was everything from the manifold back). You won't have to drop it all like I did, I just did it because it was simple enough and that kept it all in one piece.
